edwardstuff
Dec 05, 2022Follower
IPHONE 13 pro Max dropped call issue
Using Netgear X6 R8000 Netgear EX7700 extender my iphone 7 never had a problem, always used Smart Connect Now I always have Issues especially with sending pictures, take forever to send. Calls ...
Dec 05, 2022Guru - Experienced User
What Firmware version is currently loaded on the router and extender?
What is the distance between the router and extender? 30 feet is beginning distance.
What is the SQ feet size of the home?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
