pmfrva
Oct 16, 2021Aspirant
iPhone 1mbps Mac 100mbps: Weird
Upgraded iphone recently. Now getting very slow speeds on wifi (1mbps). Other connections are fine (100+mbps). (Also happening with other upgraded iphones in home). On latest firmware Turned pr...
Oct 16, 2021Guru - Experienced User
so only the upgraded phones have the issue?
Everything else works fine?
Did you try factory resetting any of the phones?
Or contacting apple on why it might happen just to their devices after an update?
pmfrva
Thanks for the suggestion
Phones work fine on other Wi-Fi networks. So, thinking there’s a specific issue on the handshake on home network
- plemansOct 16, 2021Guru - Experienced User
did you go in and "forget" the network on the iphone?
or reset the network settings on the iphone?
