pmfrva
Oct 16, 2021Aspirant
iPhone 1mbps Mac 100mbps: Weird
Upgraded iphone recently. Now getting very slow speeds on wifi (1mbps). Other connections are fine (100+mbps). (Also happening with other upgraded iphones in home). On latest firmware Turned pr...
pmfrva
Thanks for the suggestion
Phones work fine on other Wi-Fi networks. So, thinking there’s a specific issue on the handshake on home network
Oct 16, 2021Guru - Experienced User
did you go in and "forget" the network on the iphone?
or reset the network settings on the iphone?
- pmfrvaOct 16, 2021AspirantYeah, that hasn’t helped.
- pmfrvaOct 16, 2021AspirantHere’s another clue. If I connect to my guest network, no problems. Totally confused
- plemansOct 16, 2021Guru - Experienced User
did you contact apple at all?
If you do a quick google search on iphone wifi slow downs after an update, you get a bunch of responses. Not sure exactly what update you did but might be worth checking with them on.
