Rob818's avatar
Rob818
iPhone 6 wifi calling
On about 50-60% of calls with my iPhone 6, when either I make a call or receive one, I will hear the caller for a second and then their end goes silent and I can hear nothing. They can sometimes hear ...
  • FURRYe38's avatar
    Yes, log in to the routers Web page.
    Some of the features mentioned are located under Basic and Wireless. The others are located under Advanced/Setup/wireless, etc or Advanced/Advanced Settings/Wireless
    I would also make sure that all iphone apps are closed or not running as well. They shouldn't be interferring however you never know. :smileyfrustrated:
