IPFred
Oct 18, 2020Aspirant
iPhone won't connect to R8000
I use the R8000 for my Home network. Both my iPhone and iPad won’t connect to the normal WiFi Access Point but can connect to the Guest network. When I check my iPhone / iPad I see that they don’t get an IP-address. Both are running IOS14. What is wrong??
Had enabled the network Access Control before, and you were able to connect to the router from the primary (non-guest) Wi-Fi?
if yes one might guess this has changed with the recent iOS 14 update. Any related mis-credit related goes to Apple for defaulting all existing wireless configurations on the device to the tin hat "private Wi-Fi addresses" -> Use private Wi-Fi addresses in iOS 14, iPadOS 14, and watchOS 7 - how to disable it for your network names/SSIDs is part of that document.
- IPFredAspirant
Hi schumaku,
Network Access Control was the Solution! It works, thank you!
IPFred wrote:Network Access Control was the Solution! It works, thank you!
Well, the real solution would be to disable the "private Wi-Fi addresses" feature randomizing Wi-Fi Mac addresses as there is no reason for not using the real hardware address on a home or business WLAN.
