LGB
Dec 22, 2018Aspirant
iphones will not download apps or updates on wi-fi.
Within the past few months I have lost the ability to download any apps or even updates for my apple devices when connected to wifi. I called Apple to troubleshoot and there is no problem on their e...
- Dec 22, 2018I would suggest resetting the router to factory defaults and then redo all the router settings from scratch. And when you do the new network password, only use upper and lower case letters, NO repeat NO special characters. I’ve seen those cause App Stores and other issues with all mobile devices, not just iOS. Same with the admin (router login) password - NO repeat NO special characters, upper and lower case letters and numbers ONLY.
Let us know if that helps.
Richard1864
Dec 22, 2018Luminary
On your iPhone(s), go to Settings>General>Reset Network Settings. Your iPhone(s) will reboot and clear out all network settings and DNS caches. Then reconnect to your router and see if that fixed things.
How old are your iPhones, and do you have the latest version of iOS installed on them (iOS version 12.1.2)?
LGB
Thanks. I already cleared everything when talking with Apple Support. We are using iPhone 7s. It didn't work. All phones are running the most up to date ios.
- myerswDec 22, 2018Master
You say you cleared everything with Apple. If you are saying you have things working after talking with them it would be nice of you to share the fix.
- LGBDec 22, 2018AspirantUnfortunately, even after talking with Apple, and clearing the phones, I still cannot download apps. It is the Netgear router because I can download them in any other WiFi connection.
- Richard1864Dec 22, 2018LuminaryI would suggest resetting the router to factory defaults and then redo all the router settings from scratch. And when you do the new network password, only use upper and lower case letters, NO repeat NO special characters. I’ve seen those cause App Stores and other issues with all mobile devices, not just iOS. Same with the admin (router login) password - NO repeat NO special characters, upper and lower case letters and numbers ONLY.
