Inyalga
Mar 28, 2023Follower
IPV6 Failure
Hello i require assiantce So i used a netgear nighthawk modem for my gaming but i noticed that it always bottlenecks the actual intended network When i turn it on its crazy good and overtime the...
michaelkenward
Mar 28, 2023Guru - Experienced User
Inyalga wrote:
im supposed to have 60more mbps than what i have normally
If that is a WiFi connection, it will never deliver what you "have normally", whatever that means. It is how WiFi works.
But as plemans says, we know nothing about your network. Indeed, it isn't at all easy to follow what you are saying.
