kwolf
May 20, 2016Guide
IPv6 ICMP Filtered
Doing the test on http://ipv6-test.com/ results in "Filtered" for ICMP, even if you disable "port scan and ddos protection" and enable "respond to ping on wan port". The problem was discussed bef...
- May 21, 2016
As I have mentioned in other threads here I worked with Netgear for months last year trying to get them to simply stop filtering the ICMP/v6 packets by changing a firewall rule and they have refused saying its a security risk. I don't understand why the network engineers at Netgear don't get that these packets must NOT be filtered for IPv6 to work properly.
Anyways it became like beating a dead horse and I finally gave up returned the Netgear router and bought an Asus RT-AC3100 and all problems were instantly solved. So the bottom line I doubt there will be any fix for this in the foreseeable future and IPv6 will continue not to work the way it was intended for Netgear routers. If you want or need a router that has real working IPv6 then you will need to buy from a different manufacture.
Retired_Member
May 21, 2016
kwolf wrote:
Is this ever going to be fixed? It's been an issue on every firmware version, even the latest "pulled" one (1.0.6.40)
In order to fix it you'd first have to admit it's a problem.
Jim769
May 21, 2016Luminary
- kwolfMay 21, 2016Guide
Thanks m8, I'll keep ASUS in mind for my next router purchase.
Honestly, if the Netgear engineers are too dense to understand the extremely basic FACT that ICMP in IPv6 is a fundamental requirement of the protocol, I wonder what else is overlooked in the router firmware. This certainly doesn't bode well for future firmware releases. No wonder the past few firmwares have been completely botched, with this caliber of "engineers" working on them...
- JamesGLMay 26, 2016NETGEAR Employee Retired
Hi Kwolf,
Please update your R7000 to the latest firmware v1.0.5.64.
- Jim769May 30, 2016Luminary
JamesGL wrote:Hi Kwolf,
http://kb.netgear.com/app/answers/detail/a_id/30695
Updating firmware is normally a good thing but from what i hear the IPv6 filtering ICMP/V6 packets is once again not fixed in the new release. Please someone correct me if i am mistaken.
