kwolf
May 20, 2016Guide
IPv6 ICMP Filtered
Doing the test on http://ipv6-test.com/ results in "Filtered" for ICMP, even if you disable "port scan and ddos protection" and enable "respond to ping on wan port". The problem was discussed bef...
- May 21, 2016
As I have mentioned in other threads here I worked with Netgear for months last year trying to get them to simply stop filtering the ICMP/v6 packets by changing a firewall rule and they have refused saying its a security risk. I don't understand why the network engineers at Netgear don't get that these packets must NOT be filtered for IPv6 to work properly.
Anyways it became like beating a dead horse and I finally gave up returned the Netgear router and bought an Asus RT-AC3100 and all problems were instantly solved. So the bottom line I doubt there will be any fix for this in the foreseeable future and IPv6 will continue not to work the way it was intended for Netgear routers. If you want or need a router that has real working IPv6 then you will need to buy from a different manufacture.
Jim769
May 30, 2016Luminary
JamesGL wrote:Hi Kwolf,
Please update your R7000 to the latest firmware v1.0.5.64.
http://kb.netgear.com/app/answers/detail/a_id/30695
Updating firmware is normally a good thing but from what i hear the IPv6 filtering ICMP/V6 packets is once again not fixed in the new release. Please someone correct me if i am mistaken.
JamesGL
May 30, 2016NETGEAR Employee Retired
Hi Jim769,
I would suggest to try the latest firmware and see if it has the same problem. I haven't not seen any feedback from other users that it has the same problem.
- Jim769May 30, 2016Luminary
JamesGL wrote:Hi Jim769,
First and foremost i dont own a Netgear router, been there done that. I have not seen any feedback that says it has been fixed. They never fixed it for the last 3 years.
- Retired_MemberJun 01, 2016
If the release notes don't include IPV6 in it's fixed list then I doubt it fixed itself.
- Yacht_RockedJun 10, 2016Aspirant
I have a Netgear R6400 on Firmware Version V1.0.1.6_1.0.4 . Cox has fully implemented IPv6 here, but the Router is still showing ICMP as being filtered during testing, which means this router also has this issue, and it is not fixed in this most recent firmware version. Netgear - you need to fix this.
- Jim769Jun 10, 2016Luminary
After talking with Netgear many times over this and there stance of filtering ICMP/V6 packets because they believe if they dont it's a security risk, i have come to the fact that all Netgear routers have IPv6 that does not work properly. Unless or until they STOP filtering these ICMP/v6 packets it will remain broke.
- mbob4568Jun 10, 2016Guide
Do all Netgear routers have this firmware bug?
- Yacht_RockedJun 27, 2016Aspirant
FYI: Updated R6400 router to latest firmware released in the last few days (Firmware Version V1.0.1.12_1.0.11), and it is still filtering IPv6 ICMP. The release notes also do not address this.
- DexterJBJul 02, 2016NETGEAR Moderator
Hi Yacht_Rocked,
Let me check on this and get back to you once I have an update.
Dexter
Community Team
