Lwilson2k1
Apr 19, 2020Aspirant
ipv6 issues
I have spectrum Turned in the ipv6 in modem DHCP selected Xbox still not getting an ipv6 address Did an ipv6 test and it failed. Spectrum says they aren’t blocking and should be working. ...
- Apr 19, 2020
Go to Advanced -> Advanced Setup -> IPv6. You can select there DHCP or Auto Config (SLAAC)
microchip8
Apr 19, 2020Master
Have you tried SLAAC (Auto Config) on the LAN side?
- Lwilson2k1Apr 19, 2020AspirantHow do I find that? I’m not seeing that
- microchip8Apr 19, 2020Master
- Lwilson2k1Apr 19, 2020AspirantOk I have it on DHCP and it grabs ip’s. My iPhone I can surf to ipv6.google.com, but Xbox still not grabbing one. They say on their network setting I’m on 4 and should check out ipv6, but it still isn’t grabbing one. ....... well all be darned after numerous of the same tries it just switched over as I typed. Tyvm.
