Lwilson2k1's avatar
Lwilson2k1
ipv6 issues
I have spectrum Turned in the ipv6 in modem DHCP selected Xbox still not getting an ipv6 address Did an ipv6 test and it failed. Spectrum says they aren’t blocking and should be working. ...
  • microchip8's avatar
    microchip8
    Apr 19, 2020
    Go to Advanced -> Advanced Setup -> IPv6. You can select there DHCP or Auto Config (SLAAC)
