Javihache
Aug 29, 2020Aspirant
IPv6 not working with German provider PYUR
So guys, I've been fighting to get IPv6 to work with my router. My ISP provides IPv6 Addresses, but the router only receives them randomly or not at all. When I flash FreshTomato 2020.5 on the r...
- Aug 30, 2020
For everyone having the same problem with IPv6. Through trying to find a solution for the problem explained here https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Nighthawk-X6-R8000-wifi-5g-second-not-working/td-p/1771235
The user at the very end mentions that 1.0.4.46 solved "the IPv6 Problem" for them.
I tried this firmware and effectively solved the IPv6 Problem and the Second 5GHz Radio disappearing problem.I have deactivated Auto-Updates seeing that Netgear tends to break more than they fix with the firmware updates. I recommend everyone deactivating auto-updates. If it's not broken, don't fix it.
Javihache
Aug 30, 2020Aspirant
By the way! I forgot to mention I am on latest Firmware 1.0.4.52
- JavihacheAug 30, 2020Aspirant
Ok, spoke too early. Once the router has been rebooted, the IPv6 Address is gone and there's no way to make it work again. Also V. 1.0.4.46 doesn't work fine with the second radio. Seriously, what a **bleep** firmware Netgear offers. It's definitely the last time I buy a Netgear product.
