leejkennedy
Jan 23, 2021Aspirant
IPV6 settings for BT + R8000
Hi trying to set up this router with BT in UK. they've provided the following settings, but i do not have an option for PPPoA (or PPPoATM) on my router. using firmware V1.0.4.66_10.1.75. BT's...
michaelkenward
Jan 30, 2021Guru - Experienced User
leejkennedy wrote:
Hi
BT uses PPPoE for DSL.
There is nothing fancy about its DSL settings.
But not knowing what your modem is, who knows where it is going wrong?
If you are using the dreaded HomeHub, then it is probably a modem/router. And one that you cannot put into modem only (bridge) mode.
- antinodeJan 30, 2021Guru
That could be true. Does that mean that BT _never_ uses PPPoA?
Do you think that BT provided bad information to this fellow? Or
that he failed to convey correct information here? Or what?I can't speak for BT with the same authority as some of us claim to,
but I do know that CenturyLink uses both PPPoA and PPPoE in different
places, typically depending on the equipment (DSLAM, say) which is
available in different central offices and/or historical policy
decisions.
