PaulGo's avatar
PaulGo
Luminary
Jun 15, 2022
IPv6 With Verizon FiOS
I also have a Netgear R7000P router, which I use with Verizon FiOS.  Recently, Verizon has implemented IPv6 in my area and soon will be implementing throughout all areas. The R7000P when I enable IPv...
  • PaulGo's avatar
    PaulGo
    Jun 15, 2022
    I resolved the problem using the Netgear firmware!  As previously stated Auto Detect gave me a 6to 4 tunnel.  DCHP did not work.  I just tried Auto Config and it gave me a LAN Address with the WAN address blank.  However I then tried two IPv6 tests on my computer and it showed full IPv6 access.  For some unknown reason the Netgear firmware does not show the WAN IPv6 address but it detects it and uses it with Verizon FiOS.  I also tried this on my RAX45 without the same results.
