mzguy
Dec 16, 2016Apprentice
Is Beta Firmware 1.0.7.6 stable and bug-free?
I have an R7000. I know the firmware is in beta. Can anyone chime in with their experiences? Known bugs? Stability? Lost functionality? Cases of successful installation vs. bricking the router? C...
- Dec 17, 2016
We have a link on the updated Security Advisory to the production firmware.
eurosteve
Dec 17, 2016Aspirant
I updated my firmware yesterday to the BETA version. It has the same numbers as the "production" version. Are they the same? Do I need to redownload and install the production firmware?
Thanks!
IrvSp
Dec 17, 2016Master
They APPEAR to be the same, size at least. Didn't bother to try and binary compared them, just installed it. Works fine after the re-boot it does when installing.
- eurosteveDec 17, 2016Aspirant
I'm thinking that the firmware didn't change just because they changed the label from BETA to Production, as long as the firmware number stayed the same. I think they would have changed the number if they did anything to change the firmware as a result of it's trial in Beta. Does this sound right?
