fmiranda
Jan 19, 2017Aspirant
Is it possible to disable one of the 5Ghz channel on R8000?
Hello, Let me start saying that this is not an issue; But lately I noticed that using the headset Astro A50 gen3 - the A50 uses the 5Ghz channels 149-165. The R8000 has two 5Ghz bands one that ra...
fmiranda
Jan 20, 2017Aspirant
The Astro wifi base does not have the option of manually selecting the channels from the 5Ghz band. Its on auto select.
It would be cool if I could either disable the second 5Ghz band from R8000 or set the 5Ghz1 to 44 and 5Ghz2 to 48, but I can't - is there a reason for that?
