fmiranda
Jan 19, 2017Aspirant
Is it possible to disable one of the 5Ghz channel on R8000?
Hello, Let me start saying that this is not an issue; But lately I noticed that using the headset Astro A50 gen3 - the A50 uses the 5Ghz channels 149-165. The R8000 has two 5Ghz bands one that ra...
Jan 20, 2017Guru - Experienced User
fmiranda wrote:
Is it possible to put both bands within 44-48?
Usually not. You can see if it allows that on the wifi setup page.
fmiranda wrote:
Or is it possible to disable the band that act on channels 149-165?
I can see I have the option to disable 5Ghz (all bands) but not individually.
I can see that from your user manual. Most of the tri-band routers will let you do that, but apparently not yours.
