fmiranda
Jan 19, 2017Aspirant
Is it possible to disable one of the 5Ghz channel on R8000?
Hello, Let me start saying that this is not an issue; But lately I noticed that using the headset Astro A50 gen3 - the A50 uses the 5Ghz channels 149-165. The R8000 has two 5Ghz bands one that ra...
fmiranda
Jan 20, 2017Aspirant
Yeap, I noticed. But I think all of the netgear wtri-band ifi routers are like that.
Well its not such a big deal, It would be great if netgear would give that option.
- StephenBJan 20, 2017Guru - Experienced User
fmiranda wrote:
Yeap, I noticed. But I think all of the netgear wtri-band ifi routers are like that.The R8500 lets the user disable either of the two 5G bands. The 5G-1 radio is limited to the lower 5G channel range, the 5G-2 radio is limited to the upper channels.
- fmirandaJan 31, 2017Aspirant
It would be great to have that feature on R8000 routers - to disable either the 5Ghz1 or the 5Ghz2 channels. I really do not wish to use the higher channels (149-165). How to open a feature enhancement for the R8000 firmware?
I know we have the option to disable all 5Ghz signals (5Ghz1 and 5Ghz2) but I just wanted to disable the 5Ghz signal that manages the higher channels.
- JamesGLFeb 02, 2017NETGEAR Employee Retired
Hi fmiranda,
You can post under the Idea Exchange Board.
