Al-bayati
May 10, 2021Follower
is it possible to fix the region lock please ?
I bought this router from Amazon and I live in Asia, but the region router is lock in North America, and I cannot change the region.
May 11, 2021Guru - Experienced User
google burnsku command and telnet.
Basically its region locked and you can use that command to change regions.
michaelkenward
Different hardware, same approach:
Solved: WNDR3700v2 (N600) - Can't change wifi region - NETGEAR Communities.
