Parfox
Apr 16, 2020Aspirant
Is it possible to use my old Nighthawk R7000P as a Mesh router?
I am new to networking but this old dog is learning. I just purchased an ORBI system for my new home and look forward to setting it up soon. I purchased a Nighthawk R7000P AC2300 a few years ago for...
- Apr 20, 2020
Parfox wrote:
I take it that none of the satellites will use the R7000P as their hub?
I don't know what you mean by that, but if you have a satellite with a LAN port, you can put the R7000P into wireless access point mode and use the wifi and Ethernet from that.
But it will not be a mesh system and will have its own SSID and password.
michaelkenward
Apr 18, 2020Guru - Experienced User
Parfox wrote:
Are there any options to add satellites to the Nighthawk R7000P router to make a mesh network and if so, what are the recommended satellites to make this home network happen?
You can't use an R7000P as a satellite with an Orbi router.
Orbi needs its own satellites.
You could use the R7000P as a stadalone wireless Access Point or in Bridge Mode.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
- ParfoxApr 20, 2020Aspirant
Thank you for your time and response.
- michaelkenwardApr 20, 2020Guru - Experienced User
Thank you for your time and info.
I see now that the only ways to extend the range of this router's wifi is to use an extender or set it up in a bridge mode with another router.
