MikeP123
Sep 13, 2022Tutor
Is it possible to use the R9000 ONLY as a Plex server?
I replaced my R9000 router with built-in Plex server with the new Orbi 963 mesh network. My new router doesn't include a Plex server. Is it possible to disable the router and wifi capabilities of m...
- Sep 13, 2022
Thanks again. It worked like a charm.
One last stupid question. Previously when the R9000 was my router and I clicked on "Open Plex" in the Plex section of the the router's webpage, it would open the Plex Server. Now, clicking on "Open Plex" opens the webpage of my new Orbi router. Suppose I wanted to delete the current server and start fresh, how would I access the Plex server that gets created since the "Open Plex" button no longer opens Plex? I guess I could disconnect from my new network and connect the R9000 directly to my laptop if necessary, but I'm hoping there's an easier way.
Sep 13, 2022Guru - Experienced User
Sure.
Put the R9000 in access point mode and hardwire it into the ORbi.
You can disable the wifi on it or you could use it as a backup or even as a device to put IoT devices on.
Just make sure to put the wireless on different channels than the orbi.
Or you can go in and disable the wifi if you really want.
MikeP123
Sep 13, 2022Tutor
Thanks! I will try this tonight.
