css17
Jun 21, 2023Aspirant
Is it the R8300 router or the Modem or ????
I have a problem that I believe is related to my modem, router or perhaps ISP and I can’t figure out which it is and hope that you can help me identify the troublemaker. Here’s the background - Ove...
- Jun 29, 2023
css17 wrote:Yes, the DoS attack entry was in the router log file and has only happened the one time. It looks like it was related to Google and I do use Chrome as my browser.
Still no logs being sent via email but at this point it's not worth it to me to try and track it down. I did change the email in the router settings back to my Outlook one as I really don't want anything tied to an ISP email again if I can help it. Had that task of changing our emails from Comcast when we moved from Seattle to Oregon and only had Charter (Spectrum) to choose from. What a pain....
I am definitely a list maker and identifying the devices attached to the router and putting them into Excel with their pertinent information is a good idea. I will do this and be sure to check out each new device that I add to the network in the future. Since the "Device Name" issue is known and kicked around I'm not going to worry about it. I just thought if it was an easy thing to do I'd stick a name in there that meant something to me. I just wish that everybody would play nice together. It was so much easier when it was just IBM hardware and software. I'd just call our IBM system rep when I needed help. Now, in the PC arena there are so many different hardware and software components it's hard to know who to contact or even how to drill down to the right piece of hardware/software causing the problem.
Which brings us full circle. I started here not knowing whether it was my modem, router or ISP that was causing my Outlook and Acronis issues. I never would have figured out the different settings within the router and things to try without all of your help. If I had gone out and bought a new router and/or replaced the modem I'd more than likely still be experiencing the same problems. The send/receive errors in Outlook 2016 have disappeared and all of the emails sent from Acronis have arrived just as they should. And I've learned a bit more about router settings and how all of this stuff works together (or, at least is supposed to). I've documented everything I've changed so I have it as a reference point in case this pops up again.
I want to thank you both for helping me out and explaining things to me. I may not have been in the right spot but intuitively knew that someone here would have the knowledge to help me work through it. Thanks for sharing your time and experience with me.
All the best - Carol
An ongoing education is why this place exists, and it goes both ways. Good luck!
Kitsap
Jun 24, 2023Master
You have been tweaking on this network pretty hard for the past couple of days. Progress has been made.
Recommend you turn off your computer then power down (pull the power cord) for both your modem and router.
Give it a few minutes then power up the network in sequence from the outside in. Power up the modem and give it plenty of time to connect and stabilize. One of the last indicators you will see illuminate is the internet connection. Power up your router and give it plenty of time to boot and stabilize. One of the last indicators you will see illuminate is the internet connection. Boot your computer and check your e-mail.
Give the whole network a couple of days to run and see how your notification e-mails are coming through.
One other thing to check is your spam/junk mail folders on your e-mail servers. You have to log in to your web mail as you cannot see these folders through e-mail client programs.
michaelkenward
Jun 24, 2023Guru - Experienced User
Good advice.
This saga tells me that Netgear should put some effort into updating the instructions for getting logs to work with SMTP servers.
An FAQ on the general issue might also help. It is rarely a router thing when it comes to other devices, but, as we have seen here, this is often the first place that people come to for help. (They do that for just about any problem that involved traffic through the router.)
Search - NETGEAR Communities – smtp logs
This is a bit thin on detail:
I have just discovered a note I added to the login details I use for outlook.com. It reads:
Does not work with R7000P
Great.
