Akuchew
Apr 15, 2022Aspirant
Is my NightHawk R7800 dead?
(Win10) Was noticing very high latency on a game. Decided to factory reset the router. When using the Nighthawk App to set it all up again, I cannot connect. I've tried 4-5 times with the app. My ph...
Apr 15, 2022Guru - Experienced User
Set up the router with a wired PC or laptop and web browser.
wcalifas
Apr 16, 2022Prodigy
I wouldn't try reaching your router with the netgear app. I'd try either wired or with the phone that says its connected. Instead of using www.routerlogin.net try it through 192.168.1.1. Let us know if that helps or to see what happens.
