MoncRT
Feb 04, 2023Aspirant
Is my R8000 Toast? Weak signal, only one 5g band broadcasting
Hello all Question, I have a nighthawk r8000 router (tri band) and two of the networks (one 2.4 ghz and the 2nd 5gz) according to my son started going on and off while watching the networks from ...
michaelkenward
Feb 05, 2023Guru - Experienced User
MoncRT wrote:
When I got home, I took a look and they weren't even broadcasting anymore. After going into the router setup page, it shows they are both broadcasting. I shut off broadcasting, rebooted, then turned broadcasting back on to no avail.
What do the WiFi LEDs on the router look like? (Check the LED On/Off switch on the back.)
Did someone press the WiFi On/Off button on the top?
- MoncRTFeb 05, 2023AspirantYeah I forgot to add that.. They all show on for both frequencies.. I toggle the physical switch on and off as well... no changes
