kanan11
Dec 10, 2023Follower
Is my router junk?
I have a nighthawk ax8 and randomly we lost WiFi the other day. I noticed the gfci outlet the router was plugged into went bad. So I replaced it. Still no WiFi, we called Verizon internet and they sa...
michaelkenward
Dec 10, 2023Guru - Experienced User
kanan11 wrote:
we called Verizon internet and they said there was a problem, at the street and it will need to be fixed.
Did they fix it?
What firmware version do you have on the unknown Netgear device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
