kanan11
Dec 10, 2023Follower
Is my router junk?
I have a nighthawk ax8 and randomly we lost WiFi the other day. I noticed the gfci outlet the router was plugged into went bad. So I replaced it. Still no WiFi, we called Verizon internet and they sa...
Dec 11, 2023Guru - Experienced User
When just the power comes on and its amber, it tends to indicate either a bootup or firmware issue.
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash an issue.
