HammSilv
Oct 08, 2021Aspirant
Is Nighthawk R7450 PoE Enabled?
Hello all, I am about to extend the WiFi with a ceiling-mounted AP, so I need to know if the R7450 Nighthawk AC2600 WiFi Router supplies Power over Ethernet through one of the 4 ports. Thanks.
- Oct 08, 2021
No.
PoE comes on some LAN switches though.
Oct 08, 2021Guru - Experienced User
No.
HammSilv
Thanks for the information... I suspected as much since there is no mention anywhere else.
I really didn't want to pace another node, that's why I was asking.
- FURRYe38Oct 08, 2021Guru - Experienced User
Most home class routers don't support PoE, thats usually kept to the LAN switches.
