HammSilv's avatar
HammSilv
Is Nighthawk R7450 PoE Enabled?
Hello all, I am about to extend the WiFi with a ceiling-mounted AP, so I need to know if the R7450 Nighthawk AC2600 WiFi Router supplies Power over Ethernet through one of the 4 ports. Thanks.
  • FURRYe38's avatar
    Oct 08, 2021
    No.
    PoE comes on some LAN switches though.
