chenghongkw
Mar 15, 2019Aspirant
Is the 60GHz 802.11ad working or how to turn it on
I buy this wifi router last year. I have seen that the state of 60GHz LED is solid white.
So I thought that this AP works well.
However, I bought a 60GHz adapter, but I have no access to the...
- Mar 15, 2019
Now it works. Maybe last time the new AP connected another AP.
This time I use an independent network cable.
Kamoj
Mar 15, 2019Apprentice
If you install this, you can get some info about the 60 GHz as well.
- chenghongkwMar 15, 2019Aspirant
Thanks.
Maybe my problem is from the wired network.
and this time I also didn't update the firewire of the AP and I choose router mode.
