chenghongkw
Mar 15, 2019Aspirant
Is the 60GHz 802.11ad working or how to turn it on
I buy this wifi router last year. I have seen that the state of 60GHz LED is solid white.
So I thought that this AP works well.
However, I bought a 60GHz adapter, but I have no access to the...
- Mar 15, 2019
Now it works. Maybe last time the new AP connected another AP.
This time I use an independent network cable.
Kamoj
Mar 15, 2019Apprentice
If you install this, you can get some info about the 60 GHz as well.
chenghongkw
Thanks.
Maybe my problem is from the wired network.
and this time I also didn't update the firewire of the AP and I choose router mode.
