HiHoSilver2
Jan 14, 2021Aspirant
Is the NETGEAR Nighthawk X4S AC3200 C7800 compatible with Frontier/Fios internet service?
antinode
Jan 14, 2021Guru
I'd assume not, given that a cable-TV modem+router like a Cxxxx
doesn't sound to me much like "Frontier FiberOptic Internet, also known
as FiOS by Frontier".
But, in any case, I'd ask the ISP, who should know exactly what your
"Frontier/Fios internet service" actually implies. (Rather than some
random clown here, who might not.)
HiHoSilver2
Jan 15, 2021Aspirant
Twice I contacted Technical Support at Frontier/Fios. The 1st tech told me that if the Nighthawk had the input coax connector on the rear. That when connected the unit would automatically connect to the Fios system. I was skeptical so I call again. The 2nd time the tech told no and that Fios did not have a listing of recommended substitute cable modems.
I do want to continue to pay their monthly rental fee.
- antinodeJan 15, 2021Guru
> connector on the rear. [...]A Cxxxx model does use a co-axial cable connection. Is that what
your (unspecified) current modem+router(?) uses?- HiHoSilver2Jan 15, 2021Aspirant
Yes, my current Fios cable/router uses the MoCA connection. That is why I am looking at the Nighthawk X4S AC3200 C7800-200NAS
After doing some research, before installing the new Nighthawk unit. I think that the DHCP lease on the WAN connection must be removed on the FIOS router.
