HiHoSilver2
Jan 14, 2021Aspirant
Is the NETGEAR Nighthawk X4S AC3200 C7800 compatible with Frontier/Fios internet service?
antinode
Jan 15, 2021Guru
> The 1st tech told me that if the Nighthawk had the input coax
> connector on the rear. [...]
A Cxxxx model does use a co-axial cable connection. Is that what
your (unspecified) current modem+router(?) uses?
HiHoSilver2
Jan 15, 2021Aspirant
Yes, my current Fios cable/router uses the MoCA connection. That is why I am looking at the Nighthawk X4S AC3200 C7800-200NAS
- HiHoSilver2Jan 15, 2021Aspirant
After doing some research, before installing the new Nighthawk unit. I think that the DHCP lease on the WAN connection must be removed on the FIOS router.
- antinodeJan 15, 2021Guru
> Yes, my current Fios cable/router uses the MoCA connection. [...]
"co-axial cable" and "MoCA" are spelled differently for a reason. A
model Cxxxx has no MoCA capability.At least one of us still has no idea what your (unspecified) current
modem+router(?) is (maker, model number), or to what it's connected.
> After doing some research, [...]Where? (Go ahead, say, "The Internet." I dare you.)
> [...] before installing the new Nighthawk unit. I think that the DHCP
> lease on the WAN connection must be removed on the FIOS router.To me, that sounds like the least of your worries.
