pharbrian
Mar 30, 2020Star
Is the R7000 router end-of-life for firmware updates?
I see the last firmware update for the R7000 being issued around Aug 2019. Has firmware support for the R7000 been discontinued? I have tried searching for official notification that the R7000 is no ...
- Apr 04, 2020
R7000 Firmware Version 1.0.11.100 | Answer | NETGEAR Support
Various security and bug fixes were addressed. We recommend that you restart your router before starting the update to ensure a successful update.
labatt
Mar 30, 2020Mentor
Just because there has not been a firmware update in your timeframe does not mean Netgear has discontinued support. If, on the other hand, if you are looking at a new router I would look at the Netgear AX series as this is where Ntgear will be focusing their resources and time. The r7000 shipped in 2013 so is 7 years old which is ancient by tech standards although a very well performing router. Had one when they came out and worked well, however, Netgear has managed to take an excellent router and turn it into a pile of cra& with firmware updates.
