jmajuri1's avatar
jmajuri1
is there any fix for ipv6 for the nighthawk r7000
I am running a r7000 with Firmware Version 1.0.9.12. everytime i turn on ipv6 i get real slow host resolving. I have tried all the different options in ipv6 settings to no fix. when is the ipv6 dns issue going to be fixed? Any body have ideas? i have 1 desktop to smart tvs 4 phones 1 tablet and i smart bd player.
  • It ended up being cox comunications fault. my account was not set up right.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi jmajuri1,
    Have you reset the router after the update?
    Was it working prior to the update?
    • jmajuri1's avatar
      jmajuri1
      Yes i have reset it. and i believed it worked when i first got it.
    • JamesGL's avatar
      JamesGL
      Hi jmajuri1,
      Can you try to load the previous firmware and check if the same problem.
      • jmajuri1's avatar
        jmajuri1
        I tried going back as far as version 1.0.7.2. It never fixed the problem and I believe that is older then what it shipped with.
