Scottie01
Oct 06, 2021Guide
ISP Remote diagnostic tests reset router to default settings
I have been using the R8000P for a number of years and I have a lot of customised settings, including reserved IP addresses for 50+ devices. The default admin password has been changed to a strong p...
Oct 06, 2021Guru - Experienced User
gotta admit, this is the first time I've seen an ISP be able to remote reset a router that isn't a modem/router combo device.
what firmware version is on the router?
Scottie01
Oct 07, 2021Guide
Router is using Firmware V1.4.1.68_1.3.28 which is the latest. Auto uupdate is on.
I have had these problem several times before, at least twice, so this is not a new problem for me. My ISP Superhub is set to "Modem only" mode (since it is such a poor router). I don't know if this is evident to the ISP, I suspect it is.
Anyway, somehow these diagnostic / reset signals sent from the ISP come through to the R8000P and cause it to reset to factory settings, something I'd only texpect to be possible by either pressing the reset button on the router (wherever that is) or by admin user initiation based on login to the router.
I suspect that one way to avoid this in the short term will be to disconnect the ethernet connection between the ISP modem (Superhub) and the router (R8000P) before making a call to the automated ISP fault reporting service. The service can then only reset the modem! However, this does not address the problem with the R8000P allowing/re-acting to these diagnostics with a reset.
- plemansOct 07, 2021Guru - Experienced User
A couple things to try.
1. the .68 isn't the latest. 1.4.1.82 actually is. Doesn't mean its the greatest though. I've seen posts before on versions that caused resets when people rebooted devices. If thats actually whats happening, then sometimes downgrading a version can help.
2. the superhub might not be that great. but it should be capable of routing hardwired devices. Have you tried putting it back in router mode and then either putting the netgears IP address into its DMZ or putting the netgear in access point mode?
- Scottie01Oct 08, 2021Guide
I haven't tried using the R800P as an AP. It is not really an option for my Network. The reason I bought the R8000P was:
1. the Virgin Media Superhub could not handle in excess of 30 Reserved IP addresses
2. It could only handle 2.4GHz or 5 Ghz. It was not SMART like the R8000P in being able to offer Dual Bands sultaneously.
3. The user interface was terrible to say the least
So, I need it to decode the ISP signal only, leaving the Routing to the vastly superior R8000P.
- plemansOct 09, 2021Guru - Experienced User
It would be ideal for the R8000P to handle all the routing.
but cascading routers can cause issues, especially when they're sketchy/poorly coded devices (as you're finding out).
that means sometimes you have to try different things to see what'll work decently with the gateway.
did you try using the DMZ option I outlined?
Or did you try the AP mode to see if it'd work?
