Italiangen2021's avatar
Feb 03, 2022
ISP Throttling
Thanks for taking my question?   Do ISP still use a Throttling- down of speeds when my new router is installed?  Does Netgears speed checker (NightHawk - bitdefender) tell me if throttling?   Doe...
  • microchip8's avatar
    microchip8
    Feb 04, 2022
    You can get the latest firmware from here: https://www.netgear.com/support/product/R6400v2.aspx#download
    Usually, ISPs throttle specific protocols, like File Sharing, and not the whole spectrum. This means that your speedtests may come out just fine, but if you start a File Sharing download, it can be throttled. ISPs often use DPI (Deep Packet Inspection) to look into and throttle accordingly
