Italiangen2021
Feb 03, 2022Aspirant
ISP Throttling
Thanks for taking my question? Do ISP still use a Throttling- down of speeds when my new router is installed? Does Netgears speed checker (NightHawk - bitdefender) tell me if throttling? Doe...
- Feb 04, 2022
You can get the latest firmware from here: https://www.netgear.com/support/product/R6400v2.aspx#download
Usually, ISPs throttle specific protocols, like File Sharing, and not the whole spectrum. This means that your speedtests may come out just fine, but if you start a File Sharing download, it can be throttled. ISPs often use DPI (Deep Packet Inspection) to look into and throttle accordingly
Feb 03, 2022Guru - Experienced User
Netgear has set up a community forum specifically for Smart WiFi Router products. Most of the people who watch that forum are more likely to have experience with General and Smart Wifi (WN and R6000 thru R6400 Series) routers:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
Italiangen2021
Feb 04, 2022Aspirant
Thank you for your reply and sorry for the delay in getting back to you.
I can not find the Firmware ver on the Nighthawk. The ISP's Modem is a SurfBoard TM822R.
Thank you the links to the forums.
Peter
- microchip8Feb 04, 2022Master
