Steinmeg
Apr 19, 2022Star
Issue serving ip address
So not sure if others have seen this but seems once a week I need to reboot the router to get it to serve IPs on the 2.4ghz band. Checked for update, router good on updates. Any ideas, I think I had t...
Apr 20, 2022Guru - Experienced User
If you truly have the xr700 from your signature, you're not on the latest firmware.
The latest is 1.0.1.48
You might try updating and then factory resetting.
Steinmeg
Apr 20, 2022Star
Xr1000 is on the box but some more looking at it on other websites, the model is AX5400, interesting in its own the 2 numbers....
- plemansApr 20, 2022Guru - Experienced User
XR1000 is the model. AX5400 is the speed.
What modem is it connected to?
there's a newer 1.0.0.64 version of the firmware.
Again, try updating and doing a factory reset/reinstall.
https://www.netgear.com/support/product/xr1000.aspx
