DASYHRD
Oct 20, 2020Tutor
Issue with R7000 connecting to Arris SVG2482AC
Recently I had an issue with the entire internet service going down and decided to disconnect all devices from the modem and router to troubleshoot. I have a Arris SVG2482AC modem/router with Xfi...
- Oct 20, 2020
it could be because you're in a double nat.
Did you ever try the R7000 in AP mode? (access point)
Oct 20, 2020Guru - Experienced User
DASYHRD
Oct 20, 2020Tutor
Just enabled access point mode on the Netgear router and plugged in the ethernet cable into the Arris.
So far no issues. Did a speed test and it appears somewhat faster than before.
Just curious my previous setup did not need to have the R7000 in access point mode. Any idea why it needs to be enabled now?
Anyhow, big mahalos for the quick response and advice! Saved me $160 on buying another router.
- plemansOct 21, 2020Guru - Experienced User
DASYHRD wrote:Just enabled access point mode on the Netgear router and plugged in the ethernet cable into the Arris.
Just curious my previous setup did not need to have the R7000 in access point mode. Any idea why it needs to be enabled now?---Maybe the arris got a firmware update and it caused an issue? Maybe the firmware on the R7000 was updated and caused an issue. tough to say 100% what cuased it. But a double nat can cause conflicts.
Anyhow, big mahalos for the quick response and advice! Saved me $160 on buying another router. ---Glad it worked! and glad to help save some $ during these times!
