MichelleRynsai
Jul 17, 2021Follower
Issues still after R700 Hot Fix Update
Can someone please tell me if they're also having issues after installing the hot fix update? I'm still having to reboot my router 2-3 a day even after the update and it's cutting into my work as I ...
Jul 19, 2021Guru - Experienced User
After the update, did you try a factory reset and reinstall?
Its the first thing I recommend if people are having issues after a firmware change
