Herman99
Sep 26, 2023Aspirant
Issues with iOS 17.0.2
I am having issues with my new iPhone 15 Pro. It does not see the 5Ghz option from my nighthawk router. I have contacted Apple and we tried numerous steps but they are speculating that it might be an...
Sep 26, 2023Guru - Experienced User
If your Pad, Mini and iPhone 13 are working and see the SSID then it would be the one Apple device with this most resent iOS loaded that needs to be looked into by Apple.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
What model router do you have?
Herman99
I have a Nighthawk R9000
