PLanetTeck
Mar 07, 2021Aspirant
Issues With Port Fowarding
Ive been trying to port foward to start a Valheim server with my friends but no matter what I cant seem to get the ports 2456-2458 open. Ive opened them through port fowarding on my router, Ive tried...
PLanetTeck
Mar 08, 2021Aspirant
The modem I have is the Arris TM822A and my ISP is Optimum Online
I have my port forwarding setup like this
Service Name - Valheim
Protocol - TCP/UDP
External/internal Port Range - 2456-2458
Internal IP Address - 192.168.1.80
Also I am able to join the server locally but my friends are not able to due to the port.
antinode
Mar 08, 2021Guru
> I have my port forwarding setup like this [...]
Ok. Does it need/use all three of those ports? Are your friends
specifying the right address and port (if required)? With my weak
psychic powers, I can't see what they're doing any better than I can see
what you're doing.
> [...] I am able to join the server locally [...]
Which kind of "locally"? Using the server's LAN IP address
("192.168.1.80", I gather), or the router's WAN/Internet IP address, or
both, or what? Are you specifying a port?
> [...] but my friends are not able to due to the port.
Does their "not able" come with some kind of error message?
> [...] due to the port.
I don't know what that means to you. _I_ haven't yet determined the
cause of your problem. It's not immediately clear to me that you have,
either.
- PLanetTeckMar 09, 2021Aspirant
I appreciate the help but I actualy got it working today thanks
- michaelkenwardMar 10, 2021Guru - Experienced User
For the benefit of other people who might turn up here in the same boat, it might help if you explained how you rescued your network.
