vinnyd51
Dec 17, 2021Tutor
Issues with R6700v3 router - "Hmmmm.....can't reach this page"
I posted an issue with this router about a month or so ago. It is in a second home and it seemed like every time we got there our internet was out. This began after the cable company installed a new ...
- Dec 17, 2021
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Dec 17, 2021Guru - Experienced User
Did this start happening after the FW udpate? If so, might go back to prior working version of FW.
vinnyd51
Dec 17, 2021Tutor
Thanks for the quick reply. The modem is an Arris model #TM2902A. This issue did start happening after the firmware update. I'm afraid to revert back to the previous firmware version so as not to have the original problem again of losing my internet connection periodically. I can live with this new issue if necessary.
