RoboGenie's avatar
RoboGenie
Initiate
Dec 22, 2016
It's time for another Unable To Connect to routerlogin.net thread
I have a R6250 Smart WIFI Router (but the field above won't accept that as a valid entry. Odd, but irrelevant for now.) It's about 1 month out of warranty -- of course. I use an iMac running MacOS S...
  • StephenB's avatar
    Dec 22, 2016
    Maybe try turning off the power on the router, then turning on the router again, and then try http://192.168.1.1 again.
    192.168.1.10 is probably your iMac's IP address, the router's address should end with 1.
