YekinKebo's avatar
YekinKebo
Follower
Sep 07, 2021
Just got a Netgear Nighthawk R7000 router... having issues.
I've been wanting to replace a modem/router combo I've been using for some time now. Replaced an old Charter Netgear m/r combo because finally after 4 years issues arose. They gave me a Cisco modem. Told me I could get the Spectrum WiFi package (like an extra $5 or $10 a month), or use a modem by them and I could buy my own router.
So I Decided on getting a Nighthawk R7000.
I have been trying to get this hooked up for the past hour or so and nadda.
Followed directions to a T. Even looked at some how to install vids on Youtube just incase I thought I might've over looked a step and followed them to a T to no avail.
Any tips, suggestions are appreciated.
1 Reply
  • You don't say exactly what problem(s) your have (no internet?/connection issues?/wifi issues?) and how you are trying to set it up. Set up is best done over a wired connection (no stupid apps) and using the Web UI of the router at http://routerlogin.net or http://192.168.1.1
