RockoSweat's avatar
RockoSweat
Keep ISP from broadcasting hidden SSID network using your router + Nighthawk R7000
The problem: My ISP broadcasts a hidden SSID network (or two) using my router. The network(s) follow my home network around, regardless of what channel I put it on. I've spoken with the ISP in the pa...
  • RockoSweat's avatar
    RockoSweat
    Jan 28, 2022
    Hey there,
    All of your questions got me looking and playing around with a lot of different devices, settings, ect.
    I was wrong. It looks like the hidden SSID which was causing me the most issues was a network created by Google Chrome Cast which was later revealed to be Living Room TV.[x] . I didn't use that device too often, so I unplugged it and the issue was solved. No more hidden SSIDs. At least on my 2.4 ghz network anyways. When I looked at the 5 ghz network, there were still two networks following my network around. One was revealed to be a FireTV stick, and the other is still unknown. At the moment, it doesn't appear to be causing any issues with media playback on my TVs. If it does, I will use the MAC address suggestion someone posted here.
    Turns out, I had a configuration error. Both of my networks had the same exact name. Once I changed the names of both networks, three of the four "hidden" SSIDs revealed themselves and I could then mitigate the issue from there. At the moment, everything seems to be OK. I will continue to monitor the 5 ghz network to see if there are any playback issues with the other two networks present.
    Also, just for clarity, I didn't have an ONT, but just a CAT 6 plugged into the wall, and then a cable line running from my house to the telephone poles. And thank you for the update recommendation; the devices connected to my router now have pictures that show what they are if the name is not specific enough. Thanks.
    Thanks to everyone for your help/suggestions!
