RockoSweat
Jan 28, 2022Aspirant
Keep ISP from broadcasting hidden SSID network using your router + Nighthawk R7000
The problem: My ISP broadcasts a hidden SSID network (or two) using my router. The network(s) follow my home network around, regardless of what channel I put it on. I've spoken with the ISP in the pa...
- Jan 28, 2022
Hey there,
All of your questions got me looking and playing around with a lot of different devices, settings, ect.
I was wrong. It looks like the hidden SSID which was causing me the most issues was a network created by Google Chrome Cast which was later revealed to be Living Room TV.[x] . I didn't use that device too often, so I unplugged it and the issue was solved. No more hidden SSIDs. At least on my 2.4 ghz network anyways. When I looked at the 5 ghz network, there were still two networks following my network around. One was revealed to be a FireTV stick, and the other is still unknown. At the moment, it doesn't appear to be causing any issues with media playback on my TVs. If it does, I will use the MAC address suggestion someone posted here.
Turns out, I had a configuration error. Both of my networks had the same exact name. Once I changed the names of both networks, three of the four "hidden" SSIDs revealed themselves and I could then mitigate the issue from there. At the moment, everything seems to be OK. I will continue to monitor the 5 ghz network to see if there are any playback issues with the other two networks present.
Also, just for clarity, I didn't have an ONT, but just a CAT 6 plugged into the wall, and then a cable line running from my house to the telephone poles. And thank you for the update recommendation; the devices connected to my router now have pictures that show what they are if the name is not specific enough. Thanks.
Thanks to everyone for your help/suggestions!
Portwey84
Jan 28, 2022Virtuoso
RockoSweat I've just changed my R7000 for a TP-Link GX90 and I also have a 'hidden' locked network sat there in the background that cannot be accessed. I believe it's coming from my router, not from my ISP. I believe it has something to do with Onemesh to build up the wireless mesh system. I'm wondering if this is also applicable to Netgear for their wireless mesh system? In any case, it isn't causing me any issues.
Kitsap
Jan 28, 2022Master
In Wi-Fi Analyzer, go to the Access Points page, behind the SSID either what it shows or *hidden* and you will see in parentheses the MAC address of the source. Some devices have a separate MAC address for the wireless radios and one for the ethernet port.
