urzaseye's avatar
Jul 06, 2016
"LAN access from remote" log entries
I've been looking over my daily router logs for the last few days and keep finding this entry sporadically:   [LAN access from remote] from 184.105.247.199:32931 to 10.8.108.64:5353, Wednesday, Jul...
  • TheEther's avatar
    Jul 07, 2016
    Port 5353 is commonly used for Multicast DNS (Apple calls it Bonjour).  It's unusual to see a remote device access this port.  In addition to disabling port forwarding/triggering, make sure that UPnP and DMZ are disabled, too. Those are the two other vectors by which a remote device could access the internal network.
