pbneu
Jan 17, 2021Aspirant
LAN access from remote R7000
I continue to have the following entries or similar even if disabled UPNP, DMZ and port forward/triggering... also the remote management of the router is OFF. How this is possible ? Any idea to hel...
antinode
Jan 17, 2021Guru
> [...] R7000
Firmware version? Connected to what?
> How this is possible ? [...]
I don't know. What's at "192.168.1.19"? My quick Web search
suggested that port 5061 is used for VoIP.
Lacking any rational explanation, I'd try a settings reset on the
router, and a manual reconfiguration, making sure (again?) that those
features are disabled.
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Not a router.
pbneu
Firmware Version
connected to a router(bridge mode) from the ISP (internet service provider)
192.168.1.19 is a VOIP unit, correct. But with all closed (double checked UPNP, port trig/forward, DMZ, remote management) there should not be any LAN access
Model R7000, sorry for the mistake...
- antinodeJan 17, 2021Guru
> remote management) there should not be any LAN accessI agree. Now, if only you can persuade the router...
Bugs in Netgear router firmware have been detected in the past. I
know nothing, but I'd do the settings reset and reconfiguration without
the "a VOIP unit" connected, re-verify the no-incoming settings, and
_then_ connect the "a VOIP unit". If the router wakes up with UPnP
enabled, and the "a VOIP unit" is connected, then I can imagine that it
might gets its dibs in on that port before you can disable UPnP, and,
once in the table, it might stay in the table. But what do I know?
