connorsapps
Oct 23, 2022Tutor
LAN Invalid MAC address.
 When going to add a static ip under Advanced > Setup > LAN Setup. Going to add an address reservation don't work for any of my devices. When clicking add I get the message:     Invalid MAC address. 8...
- Oct 23, 2022
This is a known issue and has been passed on to NG.
Find downloads here;
https://www.netgear.com/support/product/R8000P.aspx#download
connorsapps
Oct 23, 2022Tutor
Note: this was previously working before router software update.
Oct 23, 2022Guru - Experienced User
After the update, did you try a factory reset?
If that doesn't help, you can always downgrade back to the older version of firmware.
- connorsappsOct 23, 2022TutorI’ve tried a factory reset. I’ve looked into rolling back the version a bit but is there a way to find older downloads?
